Special tool?
Old 07-19-2010 | 11:39 AM
RICK167448's Avatar
Special tool?
Hi!: I have a 2007 HHR LS. I attempted to replace the reading lamp bulbs in the rear view mirror. I was successful in removing the bulb covers, but I could not get the bulbs out. Is there some type of special tool that is used to grip a light bulb and make removing it easier? Thank you!
Old 07-19-2010 | 10:35 PM
Gas Man's Avatar
Very small needle nose pliers... some effort with finese. They'll just pop out...
Old 07-19-2010 | 11:00 PM
87silver's Avatar
Try Xcelite 4" subminiture needle nose pliers. Good for electronic projects as well.
http://www.testequipmentdepot.com/xc.../4inpliers.htm
Old 07-20-2010 | 12:15 PM
RICK167448's Avatar
Thank you. That was a very good suggestion. I will try it.
Old 07-20-2010 | 12:17 PM
RICK167448's Avatar
Thank you for the suggestion and the information about the pliers. I will pick them up and try the. Thanks once again!
Old 11-17-2010 | 09:15 PM
ymerej_mortsdnil's Avatar
Question
anyone use anything else special to take out the bulbs in the rearview mirror? I tried for at least 1/2 hour to take them out by hand with no luck
Old 11-18-2010 | 05:58 PM
BlackknighT's Avatar
Xcelite is great-I use them for circuit board work. I have the older light blue foam handle set from the early 80's that say xcelite in black-a nice bunch of mini tools plus interchangeable drivers & ends. Couldn't affort the set now though. A little expensive for a regular person but maybe if there is a Harbor Freight store near you check these-
http://www.harborfreight.com/hand-to...set-31675.html
I use small needle nose with 3m double tape on each jaw then close it around the bulbs in my 2003 impala rear view. Don't tell anyone my secret
Old 11-19-2010 | 03:34 PM
HHorange's Avatar
Usually a piece of soft plastic hose forced over a pull out bulb, will be enough to then pull the bulb out..... Be careful it you use pliers as its usually very easy to brake the bulb.
Old 11-20-2010 | 05:55 PM
Thumbs up
Great idea
Thumbs up
ANOTHER great idea
Oldblue
"How To" Tutorial Library
17
04-28-2022 06:04 PM
working on it
Maintenance and Upkeep
28
03-02-2014 09:05 PM
R CA HHR
04-25-2011 12:51 AM
bodywerks
03-02-2009 03:13 PM
