Squeaking sound from rear
Old 06-14-2010 | 10:13 PM
Lake Runner's Avatar
I have noticed that there is a squeaking sound coming from what appears to be the rear area of the car when making slow turns. This is usaully with the body and suspension leaning and settling. I hear it every time I drive in the parking garage at work. Slight off camber turns cause it the most. The HHR has 53k miles on it BTW. I checked under the car for loose components such as the muffler and tail pipe and could fine nothing.
Anyone else have this issue. Thanks in advance.
Old 06-15-2010 | 08:20 AM
HHorange's Avatar
Check to see what the spring isolation pads look like between the springs and the body. After last winter, both of mine had fallen apart. I found one of them in the driveway one morning......Why these were make of foam instead of rubber, I will never know.
Old 06-15-2010 | 08:49 PM
Thanks alot. I'll crawl under it again and take a look. Maybe someone makes rubber replacement.
F-16C
02-07-2013 03:02 PM
11BlueJ
07-25-2012 12:49 PM
bowtieboy68
08-17-2011 10:29 PM
BILL C.
04-12-2008 02:33 PM
Maggie's Mom
05-25-2007 02:41 PM
Quick Reply: Squeaking sound from rear
