Stalls with operation of Tilt Wheel
So I start my 2009 HHR 2LT, 25K miles and when I unlock and tilt the steering wheel down the engine shuts off like the key itself was turned to the off position.
Is this an issue with loose fuses or is this something the dealer should look at under warranty? Has anyone else had this issue?
Those seem to be the only issues I ever have, the ones that can't be recreated.
So if and when I take it to the dealer, they won't be able to recreate it and teh problem will not be fixed.
