Starter problem after ignition recall repair
Old 09-14-2014, 12:07 PM
car won't start, just clicks,
donbrew is offline
Old 09-14-2014, 12:08 PM
Welcome to the site.
Sorry for your problems.
I see whopper is answering as I type. He's spot on with his answer.
Your description sure sounds like a low or bad battery. Most of the electrical accessories will still work with a low battery even if the car won't turn over.
You could try jumpstarting it, BUT beware! Jumpstarting a HHR is a delicate procedure. Many have done it incorrectly and blown fuses in the process. Only try this if you are certain of the procedure.
Option 2 is hook up a battery charger, charge it and make sure you it has full voltage charge.
Like whopper stated, a month later it's most likely not related to the recall work.
firemangeorge is online now
Old 09-14-2014, 12:57 PM
think about it - a month later it won't start?? It won't be a missing fuse.
whopper is offline
Selmer54
GM Recall Campaigns
03-24-2015 07:07 PM
shybull
GM Recall Campaigns
43
12-22-2014 10:02 AM
frustrated
10-30-2014 03:53 PM
candyman93551
09-27-2014 06:46 AM
Quick Reply: Starter problem after ignition recall repair
