starting problem
Old 08-24-2010, 04:28 PM
galladanb's Avatar
HI Rich, We have the same issue... Seems to be heat related, Car starts and then shuts down right away... After it cools, it seems to be OK until ya need it!?!?!?!?!?
Darn thing failed at the DMV inspection today, Holy crap!!!!!
Coolant Temp showed 199, failed to start... When coolant dropped to 188, it started up. Drove five miles, temp was back up to 194, and it failed to start again.
So, where is this pin and plug thingie??? Which side of car, can ya show a picture????
galladanb is offline
Old 08-24-2010, 05:49 PM
Blue 06 LT's Avatar
I wish I would have taken pictures of everything. I didn't realize that this seemed to be a common problem. Start with the fuse box under the hood. Under it there are several plugs. The plug closest to the fire wall is the one you are after. On the wire side of the plug look for a grey wire. It will be on the driver's side of the plug. Do not unplug the fuse box. Just push the wire into it's place. On hot days the car would not start when the car was driven and completely warmed up. After the car would sit for an hour the car would start right up.
Rich
Blue 06 LT is offline
Old 08-27-2010, 09:22 AM
galladanb's Avatar
Rich,
Thx for the details... I will check it out shortly!!!!
My sweetie has our baby at work...!
Dick147
08-20-2013 07:45 PM
g bonnes
04-16-2013 10:42 AM
ChevyM84
01-24-2009 07:02 AM
Flyboy6257
09-12-2007 07:01 AM
smeedemann
07-31-2006 03:47 PM
Quick Reply: starting problem
