Steering wheel question
Probably sounds like an odd question, but when you are driving on a straight stretch of road, is your steering wheel properly centred?
I always have to have mine turned slightly to the left. If I set the steering wheel so that it appears to be centred (flat), the car moves to the right.
It's been like that since I got it. It might be an alignment issue, but the tires are wearing fine.
It can be adjusted...when I had all the BS with my Vue one of the issues was the steering wheel was loose...what I mean by loose is not side to side but pushing in towards the dash back towards me..they fixed it but when I got it back, the steering wheel was ****eyed...there are splines as he (SM) put it and the tech did not center it properly...
So my guess would be that you should be able to adjust it
Goose
Goose
No....I think it needs to be adjusted. Your alignment is probably correct, but the wheel was not centered to the alignment. As a result, I think they need to redue the alignment.
I can drive on the Interstates, and when the lane is straight, take my hands off the steering wheel and it continues straight without correction. The wheel is perfectly centered. In fact on a recent trip, I remarked how great the "road holding" is. Which really amazed me because of the comment in someones post on recent review link that stated it handled poorly at highway speeds.
I'll get them to check it and see what they say. Likely won't do it under warranty, even though it was like that at delivery.
"Clocking" the steering wheel is part of a proper alignment. Take it back to whoever did the job. It should be done for no charge, as they did not complete the alignment in the first place.
Just trying to help.
