Sticking Cargo Door
Sticking Cargo Door
My left rear side cargo door sticks and always takes at least 2 click to open it with the remote or interior switch. I can here the latch click and the seems to disengage, but it fails to "pop" open like the right side.
I have tried the trick of lubricating the door seals and that made no difference. An inspection doesn't show any mis-alignment of the door.
Can anyone tell me how this works and how to adjust it. I cannot find any signs of a "popper" so I assume this feature is an integral part of the latch assembly.
Any "clues" would be appreciated.
Remote Rear Door Operation (Panel)
*: Press and hold*for about one second to
open the rear driver side door.
+: Press and hold+for about one second to
open the rear passenger side door.
If there's a TSB on this, then that indicates a problem other than technique for sure. I will try to track down the tsb. If anyone has this or a link to it maybe we can post it here. Glad I'm not the only one with the problem.
Try lubicating the actual latches..... A latch that is not properly lubed will hang up even if it is released. Also I am not sure about the stock poppers but make sure that they are also free moving. Aftermaket poppers sometimes hang up if they are dirty or in need of lube.
I would assume lubing the door hinges would also be a good idea...
After all of that I would say you need to check for proper alignment of the door latches and latch bolt....
Just my $.02
Just my $.02
Frozen Hinges
I just had mine in and they said the problem was a need for lubrication. The work order indicated they lubricated the hinges. I checked and they certainly didn't install washers. Regardless the doors are working fine now and everything is dripping lube.
