Sticking /Locking Front Brakes.....?
.07 LT. Breaks where locking up ,felt as if the emergency brakes where on, My Mech said it was a bad Caliper , so he replaced the passenger side with a used one from the junk yard and replaced New hoses/break-lines , 3 days later Problem repeats again ,So I take it back to Mech, He replaced master cylinder witha New one , it seemed to work a few days then�� , it happens again.... I'm driving back to show him and it goes away, its working fine again ...... what do you think could be happening ��..............?
Mech is telling me to change the both calipers again with New ones , and possibly the proportioning valve , does the HHR have one ?
Not if you have ABS.
There is only 1 master cylinder.
Did he even look at the rear brakes?
Any warning lights come on?
Do the brakes just up and lock up, or do you step on the pedal.
is there a strange noise when this occurs?
too many more questions.
I don't know what could cause the problem described. I would advise against using used calipers unless they get rebuilt, but he could have rebuilt the old ones easily enough. Rebuilding calipers is a dead art.
If they are hanging the cause would more likely be the slider pins, which were probably not replaced or repaired.
Calipers are usually rebuilt and include calipers brakets and brake pads
https://www.rockauto.com/en/catalog/...b,caliper,1704
The brake hoses that go to the caliper can fail internally and not allow the fluid to return to the master cylinder. If only one side is staying on and the caliper releases when the bleeder is opened it is likely the hose.
But the first thing that came to mind is moisture or worst case scenario, the Power Brake Booster (PPB) (which I have not replaced yet).
Try cleaning or replacing and lubricating the caliper slider pins, make sure the slider pin rubber boots are not broken or torn, and flush the slider pin holes out with brake cleaner (before inserting slider pins). Also, take your cell phone light and make sure there are no broken bolts or debreis inside the slider pin holes after flushing them out.
