Strange Problem! no power at all.
Old 09-10-2011 | 09:27 AM
papasmurfsss's Avatar
Unhappy Strange Problem! no power at all.
So i did something a bit dumb I took out my under hood fuse box. I've had a lot of engine codes lately and no matter what i replace they will not go away so i checked the wires to the fuse box everything looks fine I didn't find any loose connections but now i have no power to the car what so ever. The Battery was disconnected when i did this and there is still 90% power in it. The fuses are all fine as well from the battery to the main fuse box under the hood. I am seriously at a loss here. Any help would be very appreciated, i love my HHR!
Old 09-10-2011 | 10:05 AM
nacademus's Avatar
I did that too. Did you remove then attempt to put back in the threaded studs? One of mine wouldn't go it quite right, resulting in the exact same situation you're experiencing. Try redoing the fuse box. Thread the studs to the connectors below and pull UP on them. This will further seat the lower connector that the stud threads to. Then tighten snug, like. Hand snug.
Again. Redo your fuse box. My rear wiper was going haywire, temp read "---" it was all miffed.
Old 09-10-2011 | 01:05 PM
jay loukakis's Avatar
no power?
When I first got my HHR I was going to add a chip for more HP tried to unbolt the battery cable had a mech. had to use a torque wrench and broke the small copper stripp to the fuse box no power had to use a large haed screw to make a connection to the fuse box benn that way for 3 years no problems, whty the factory had it torqued so the Chevy Dealer would not unlossen the bolt for me said the factory used Lockite? good luck.
Old 09-10-2011 | 01:33 PM
nacademus's Avatar
You're right, Jay. Dealership replaced my box due to that lead snapping. I guess its very common.
Old 09-10-2011 | 05:36 PM
Thanks Guys i'll try that and post back!
Old 09-12-2011 | 11:59 AM
I Finally got a chance to try and seat the whole assembly (i'm a volunteer fire fighter in Texas so i'm lucky i was even able to sleep at all this week) i have power but now i have a reduced engine power warning on the display. it starts and runs but no power and no power to the power steering pump.
Old 09-12-2011 | 12:11 PM
nacademus's Avatar
Its an electric engine for your steering. Its all related. Something is funky with that box.
mike321
03-05-2014 10:59 PM
Grozdev
01-08-2014 05:23 AM
slinger569
10-28-2013 10:55 AM
The Curly 1
08-26-2012 08:31 AM
rendon47
12-23-2011 02:26 PM
Quick Reply: Strange Problem! no power at all.
