Sudden Acceleration in HHR?
Old 03-04-2010, 08:39 PM
Lil Cheney's Avatar
Has this partiucular incident happened in your car? Here in NM, we have this long hill that is on the way to Santa Fe from Albuquerque. It's about 3 miles long.
Now I have had my HHR 2 years and what I am going to describ has occurred many times on this hill and I am curious if anyone else has had it.
I'm on crusie control starting up the hill. most of the time the automatic down shifting into what is more commonly known as "passing gear" works fine get a bit of an rpm increase and all is okay.
Many times it will downshift and the rpms go up by 2000 and sounds like the engine is going to blow! I'm hitting the brakes and trying to shut stuff off and what the His going on nearly losing control.
Lil Cheney is offline
Old 03-04-2010, 08:58 PM
J W Davis's Avatar
wow...
Toyota envy?
J W Davis is offline
Old 03-04-2010, 08:59 PM
urbexHHR's Avatar
Sorry, never heard of this...
urbexHHR is offline
Old 03-04-2010, 09:07 PM
87silver's Avatar
Me neither...
87silver is offline
Old 03-04-2010, 10:26 PM
ufvj217's Avatar
TOYOTA!!!!!!!!!!!!!!!!!!!
ufvj217 is offline
Old 03-04-2010, 10:42 PM
IgottaWoody's Avatar
I know that hill...I don't know your problem....I know 3 miles is a long way and not to heat up yer brakes!!
IgottaWoody is offline
Old 03-04-2010, 10:47 PM
biglefthhr's Avatar
you ansered this your self, the car is in cruise, 3 mile hill, it dowshifts to compensate for the hill, your getting worried because of engine noise that is normal when downshifing, you freak out and almost loose control, the trans will pick the correct gear fot the hill it must be a steep one!!!!!
biglefthhr is offline
Old 03-04-2010, 10:49 PM
biglefthhr's Avatar
it may downshift more than once to a lower gear for the hill!!!
Old 03-04-2010, 11:23 PM
XtremeSS's Avatar
Do you have air conditioner running while driving up hill?
XtremeSS is offline
Old 03-04-2010, 11:38 PM
prod's Avatar
If your road speed stays the same and it doesnt get into the redline rpms on the tach, then there is no problem.
prod is offline
Quick Reply: Sudden Acceleration in HHR?
