Sun roof will not open
Old 06-19-2015 | 07:47 PM
Dbeluscak's Avatar
Sorry to dig up an ol thread. I'm having an issue with my sunroof in that it won't open. It will start to open, lower, and move maybe a 1/4" then just clicks. It appears to be hanging up on the drivers side. Just wondering if anyone has had a similar problem.
Does the headliner need to come out for me to really get at it?
08 HHR SS
Old 06-19-2015 | 07:56 PM
Since it won't open, yes via the headliner.
Rather than hijack the other thread, I've moved the post from the How-to section, to it's own thread in the Problem/Service section.
Old 06-20-2015 | 06:17 AM
If you can, you should inspect the track. You could be lucky and just need to remove some dirt or apply some lube.
I don't have one, so I don't know how accessible the track is.
Old 06-22-2015 | 04:11 AM
Lucky's Avatar
Any dents in the roof? I know there is not a lot of room for the glass to slide under the roof panel.
Old 06-22-2015 | 10:37 AM
Dbeluscak's Avatar
Nope no dents. I believe it's either jammed up or something has broken in or on the left track. It really tries to move, just can't.
Old 06-22-2015 | 11:10 AM
Could be the gear stripped or drive cable broken.
Could be the popup wind deflector.
A careful disassembly will find the issue, good luck.
Old 06-22-2015 | 05:51 PM
Dbeluscak's Avatar
I figured it could be a number of things. I have a borescope so I'll run it along the tracks to see what I find. Is the drive and such towards the rear?
I'll do an in depth how to on my findings as the hhr seems to have a lot of sunroof issues. Mine is an 08 SS with the pillar air bags as well.
That is, if I have to take the headliner out. I plan to in the future adding an entertainment center for the kids.
I can't test anything out right now as I've got all the fuse panels out prepping the engine bay with a fresh coat of victory red!
Old 06-22-2015 | 06:15 PM
Not sure if this will help or not.
Old 06-22-2015 | 06:35 PM
Looks like the motor is at the back end of the frame
Old 06-22-2015 | 07:57 PM
Dbeluscak's Avatar
That does help are there any descriptions on parts 1-8? I can pick out half of them. In wondering if 1 is the frame and 2 is the window itself. From the pic it looks like the moving parts(+tracks to clean) are part of #1.
Quick Reply: Sun roof will not open
