sunroof drain hole location
Old 02-20-2010 | 10:49 AM
malcolm's Avatar
does anyone have a picture of the sunroof drain hole location? I have a leaky roof when I go through a high pressure car wash and the water runs into the cabin through the open/close switch area. Thanks in advance for any help.
Old 02-20-2010 | 11:22 AM
the_shmoo's Avatar
This thread may help.
https://www.chevyhhr.net/forums/show...?t=770&page=29
Old 02-20-2010 | 11:30 AM
malcolm's Avatar
thanks shmoo....
Old 02-20-2010 | 11:53 PM
the_shmoo's Avatar
You are welcome. Glad I (we) could help.
Old 02-27-2010 | 02:08 AM
Are you sure the leak isn't coming from the antenna? It sits right above the switches, and you would probably notice any water leaks around the sunroof area first, if the leak was related to the sunroof.
Old 03-09-2010 | 10:12 AM
malcolm's Avatar
Maybe it is leaking around the antenna. I'm not sure. I think I'll just avoid the high pressure washes....
Old 05-23-2014 | 07:57 AM
Cheletwin2's Avatar
Found this image, there appears to be a third drain line.
http://parts.nalleygmc.com/images/pa...191T12-017.JPG
Old 05-26-2014 | 11:57 AM
Lee3333's Avatar
I always figured there had to be a rear drain, although I don't know how you could reach it without taking the whole sunroof apart. My 2 front drains were very clogged up creating a flood in my car whenever it rained.
Old 11-13-2014 | 01:03 PM
TOMBULLDOG's Avatar
Sunroof drains
I checked with the dealer and there are drains at the rear corners, each side. You can see the drain lines in the spare tire area. They drain thru the rear panel below the covering around the rear hatch latch. I passed air thru the lines but nothing changed. The lines connect to the sunroof assembly at the back corners just like the front. It looks like the headliner must come down.
Any better solutions are welcome. Please, I haven't fixed mine yet!!
If your drains are disconnected at the sunroof you will also have a moist smell from the front seatbelts.
Old 11-13-2014 | 01:06 PM
TOMBULLDOG's Avatar
Four drains as per Chevy parts dept.
Quick Reply: sunroof drain hole location
