Sunroof inoperative
Old 02-10-2015 | 04:51 PM
2006corvette's Avatar
Sunroof inoperative
Hi,
My sunroof is inoperative on my 2011 Chevrolet HHR.
I have checked the fuse and sunroof switch.
Any tricks changing the motor without removing all garnish mouldings and headliner or other suggestions.
thankyou1:
Old 02-10-2015 | 05:57 PM
No trick. But be sure that's the problem before you start.
Old 02-12-2015 | 05:41 PM
Hi,
Couldn't agree with you more (Make sure that's the problem - Removing the headliner is big job and several air bags to disconnect)
Do you have any suggestions if the problem is not the motor?
I have checked the fuse, checked the over head switch. I have even changed the fuse and switch in the headliner.
What else could be the problem be if it's not the sunroof motor?
Thanks
Old 02-12-2015 | 07:20 PM
The fuse is #10 under the hood. There is an enable signal from the BCM. There are "vent open" and "vent closed" signals/switches. Ground is below the left rear turn signal.
Seems the only "computer" involvement is the enable signal wire. I tried to post a pdf of the schematic, but failed.
Old 02-13-2015 | 08:54 PM
Thank You for the information
Blue Beast (aka Boydie)
03-07-2013 06:08 PM
10RedSS
05-08-2012 10:34 PM
jims08ss
07-13-2008 05:59 PM
avanbaggett
05-30-2008 06:56 PM
