Sway bar locknut
Sway bar locknut
I put new swaybar links on and the drivers side keeps loosening up and making noise. I tried replacing the lock nut but it still comes loose in about a month. Tightening it will work for a while but then it starts up again. Hate to use thread lock on it but about out of ideas. Even the wife has asked what that knocking noise is. I told her the city needs to fix the roads...
How can the nut possibly be loosening up if it has correct torque? The only reason I can think of is maybe the-ball socket in the link is not rotating as it should but rather its rotating in the sway bar. I would check see if the sway bar hole is enlarged.
which nut is coming loose….at the sway bar or strut?
Been out of town for a few days. The nut came with the link, and I didn't use the torque wernch on it. Just tightened it down as tight as possible holding the ball shaft with a pair of needle nose vise grips. Works fine for a few weeks, then comes loose. Gonna try some Blue lock-tite next, just have not been able to do much lately. I don't drive it every day anymore as I am not working so the honey-do list is overflowing....
