T/C issue.....still....
Old 10-06-2012 | 07:32 AM
CARRS 06 HHR's Avatar
Well, I've read the multiple threads on here about the intermitent T/C - hard shift - problem goes away after shutting vehicle off for a short time or replacing the intake and exhaust cam solenoids. I've replaced both of these this past week and still have the issue. I get no codes to pull, and the issue is so hit or miss, it's very hard to trace. I have checked all my fuses and the fuse block connections.
Any assistance would be appreciated.
Old 10-06-2012 | 02:01 PM
What engine? 2.2 or 2.4.
Old 10-07-2012 | 01:33 AM
No codes eh? Are you sure the code reader you are using is CAN-capable and is able to read the codes? If it is not CAN-compatible, it won't give you squat.
It might be worthwhile to drop by a Chevy dealer and see if they can get a reading with one of their units, which likely would be a more advanced unit that what we peons typically use.
Old 10-07-2012 | 07:01 AM
The engine is a 2.4, this is in an 06 with 66,000 miles. I've tried the scanner that the local Monro Muffler uses and was not able to pull any codes. I will try the local dealer. Thanks.....
Old 10-07-2012 | 11:02 PM
ewg53's Avatar
I have a 06 2lt 2.4with 60,000 miles my t/c light came on and the CEL showed exhaust cam solenoid code, I had the intake side replaced at 35,000. Anyway I replaced the exhaust soleniod and t/c light came on again for a few minutes off and on for a couple of days, but no CEL so I changed the oil as the solenoid is in in the oil passage area, after that it didn't come on again. So it worked for me.
can2blue
07-11-2013 03:34 PM
Thisstrangeengine
08-30-2011 11:39 PM
gmdealerguy
05-22-2011 01:25 PM
LewiSS
10
10-08-2010 01:29 AM
gcsd3742
07-25-2008 11:10 AM
Quick Reply: T/C issue.....still....
