tail lights stay on
Old 05-26-2016 | 07:11 PM
hurst2001's Avatar
tail lights stay on
Not to change subject but my taillights stay on touring day time and can't figure out why? They should be off its 2007 ls....I seen other hhr and there off..other then that I like work in on hhrs :-):-)
Old 05-26-2016 | 07:17 PM
Moved since that wild a change of subject is called hijacking.
Old 05-26-2016 | 08:19 PM
Are you sure it's the tail lights, not the brake lights?
Old 05-30-2016 | 05:21 AM
hurst2001's Avatar
it is the tail lights and marker lights along with drl.. This why I mention it and can't figure I out .. The lights are on automatic but if I click down on the stalk they go out like there suppose to..
Old 05-30-2016 | 06:57 AM
Then it sounds like the automatic headlight sensor may be turning the headlights to the "On" or night time setting.
Check that there is nothing covering or obstructing the sensor itself.
(It's the little bulb looking thing, center of the dash, next to the windshield glass)
Old 05-30-2016 | 09:25 AM
You mean like the estimating pad that all van drivers keep up there.
Old 05-30-2016 | 10:22 AM
Or when the dash carpet isn't aligned correctly!
Old 05-30-2016 | 01:04 PM
hurst2001's Avatar
Nothing blocking it,maybe the sensor being bad?
5tinkfi5t
09-28-2015 11:20 AM
flstss
12-30-2013 11:14 PM
irisride
11-08-2012 04:59 PM
october5
19
06-06-2012 02:06 AM
