Tailpipe knocked off center
Old 08-11-2020 | 10:11 AM
Kimberly Brooks Campbell's Avatar
Originally Posted by Oldblue
Yes it’s always a great feeling getting the job done, and you know you did it yourself and correctly! Are you using the water pump tool or changing the timing chain and balance shaft chain as well?
ive got the tool. I probably should do the chain. But I Have done so much recently. I just wanna finish up these things and get it drivable again for a bit. Lol. Need a break.
I have 196000 on her and the worse thing I ever dealt with was transmission solenoids that had to be replaced just outside of warrantee. 😒 Other than that ... just normal repairs. I have never run a code. I do most things as a preventative.
Old 08-11-2020 | 10:43 AM
It's due for the timing set, both chains, before something fails and destroys your engine.
Old 08-11-2020 | 08:56 PM
Originally Posted by Kimberly Brooks Campbell
You are welcome. Cool. Yes, Kimberly will do. All rightee then. Only a few close friends believe I do this all myself. I bet. Well. Friends and the people at the parts store. 😋. Yes good point.
Love hearing about a loving marriage. That is fantastic. Thanks, we can bark at each other at times. LOL So few marriages last nowadays. That does seem true. Does she do her own maintenance still? Only if I need a hand, but she is also a formally trained gourmet cook. So she keeps the grub good, & I try & keep the toys running.. Still ride? Yes we both do. She loves riding my 1997 Harley Road King.
And I Iike the 1994 Fat Boy or the 1973 X-Police Servi-Car. (3 wheeler w/hand shift & foot clutch) ..
Had a tiger today trying to get one control arm off. 🤬. I never heard that expression before.. But I know what you mean. The bolt turned but wouldn’t back out. Bummer. I spent the entire day trying every way I ever knew to get it out. Hate those battles. And since I’m not changing the arm. Just the bushing, I couldn’t cut it off. I hear ya..
I was about to loose my mind so I looked online and read that control arm bushing could seize on the bolt. Well, I thought, that can’t be it. The bushing has no threads. Right? Wrong.
Wrong. 🤪 Weird but true. The bushing is totally shot. Was turning with each swing. Yes I can imagine that. So I got a hefty lock wrench. Got tight grip on the bushing and my daughter came out to hold the bushing tight while I broke it loose. Good for you..
Not much better than that feeling when u overcome an obstacle. It’s just awesome. 👍 Agreed 100%, gratification for a conquered battle..
Tomorrow I’ll be getting the bushings swapped Very Cool. then I can put the suspension back together and get her drivable for a bit. Good for you. Going to do a full flush of the coolant lines before I put the new water pump in. Good deal, GM used to add clear Gel Caps to the coolant system when they built them, to ensure no tiny leaks. Be sure to get all the air out, The Rad is lower than the engine making it more challenging to get all the air to be purged out. Are you gonna be using Dex-Cool, good for 5 Years.
Don’t want any gunk in there with a new pump. No, you are right about that. I gotta drain it all anyway. Might as well start clean. 😊 Very true, & if you swap thermostats, be sure to get a GM one, aftermarket causes issues.. Many have reported here.
And the timing chains (as previously mentioned) are pretty important, with the miles yours has. Something to seriously consider. Our engines are "interference engines", meaning if your chain were to jump a tooth the valves could hit the pistons.
Sounds like a busy day coming. Have fun, I gotta mow grass, cause rains are coming.
Old 08-12-2020 | 05:34 PM
I enjoy mowing. It’s me time. Lol
about timing chains. will the car give any signs BEFORE the timing chain goes? I know it’s time. And I know it’s catastrophic if it fails. I just haven’t got the gumption yet. 😒.
I hadn’t heard about aftermarket thermostat. I just got one and made sure it was rated at 180°
Old 08-12-2020 | 06:41 PM
It is the design off the t-stat not the temp rating.
Old 08-12-2020 | 09:00 PM
  #26
I enjoy mowing. It’s me time. Lol Kimberly- I enjoy mowing as well. Just a bit hot this time of year in the South.. Gotta mow in the early AM.
about timing chains. will the car give any signs BEFORE the timing chain goes? Well my '08 2LT Panel only has a tick over 34K on it. So I haven't had to do any yet. The others know better on that. I know it’s time. And I know it’s catastrophic if it fails. I just haven’t got the gumption yet. 😒. I hear ya, Old blue has changed a couple at least, so I've read here.
I hadn’t heard about aftermarket thermostat. I just got one and made sure it was rated at 180° Something weird about aftermarket T-Stats, the HHR doesn't like them. It likes the Overly expensive GM version.
Plenty here in the archives to read about Chains & T-Stats. Just type your search title in the Search box, in upper Right. & you will get tons of threads..
Old 08-13-2020 | 07:58 AM
  #27
Any thermostat other then an AC Delco 131-158 180 degree thermostat has been documented here to not open within the parameters the computer is set for, tripping the P0128 code.
if you’re taking a break from your HHR replacement of that timing chain should be your next priority, the front guide can fail and that will ruin your day ! And your engine.
https://www.google.ca/search?q=ecote...iw=375&bih=626
Old 08-13-2020 | 01:17 PM
  #28
I think I might have lucked out Oldblue. I think that stat is the one I got, but I’ll double check before I change it. I wouldn’t even think to question an after market thermostat. So thanks for the heads up.
im doing several needed repairs and all major maintenance so I can have the Hhr in top form while I work on my daughters Jeep. Her Jeep is in need of major repairs and my Hhr will be the only vehicle between us while we work on it. So I’m taking a break from working on my Hhr ... not from driving my Hhr. 👍
the chain will hopefully wait till after Christmas. It’ll be my next project.
Old 08-13-2020 | 01:38 PM
  #29
Yes double check that new stat, I went thru 3 or 4 name brand stats until I installed the AC Delco unit, the 131-158 not the cheaper Professional unit, even that failed.
Old 08-13-2020 | 09:01 PM
  #30
The original t-stat has that nasty rubber piece the gets stuck in the opening, so no not the OEM one the AC Delco 131-158.
Just so future readers don’t get misinformation.
iluvmud
12-19-2013 08:49 PM
NickHHRSS
10-11-2009 08:13 AM
courthousedeb
47
01-22-2009 01:56 AM
GDZHHR
Mid Central
26
10-02-2006 06:57 AM
Strat Man
15
06-02-2006 07:53 PM
Quick Reply: Tailpipe knocked off center
