test don't guess ECM 2008 HHR2.2
Just for kix try jumping the run and start relay.
Fuse #5 Pin 30 is the supply for the start relay, it is always hot. . Signal is pin #86 (hot)
Pin 30 on the run relay is always hot. Signal is pin # 85 (hot)
If those pins are not always hot there is an internal fault of the fuse box.
pin 30 is hot but 85 and 86 and 87 are not. We jumped 30 to 87 and the starter spun which was a very welcome sound. But still no start. We split the fuse box but saw no obvious problem. What next?
#26
#27
we dd switch relays. did not make a difference. I guess I do not understand the difference between a post and a thread but I am happy to proceed with whichever format you prefer. It has often been said that my technology elevator does not go to the top floor.
#29
https://www.chevyhhr.net/forums/prob...m-works-58456/
#30
I removed top of fuse box but both halves look perfect. pin 30 is hot but 85 and 86 and 87 are not. Could the problem be the power coming into the fuse box ?
Hard to believe that the power will go through a jumper wire but not through a good relay. I have tried switching relays
