Third brake light not working
Old 01-12-2021 | 10:31 PM
phoenix708's Avatar
Hey all. I have read numerous threads both here and other sites. I can not lick this one. 2010 Chevy HHR. Cruise is out, and no third brake light. Supposedly if the third light is out the cruise wont work. The bulbs tested fine with a meter, and the sockets are clean. Checked for power with a multimeter, and nothing. The left, and right brake lights work fine. I tried testing with the hazard switch, and still nothing.....no third light but left, and right blink. Checked the number 9 fuse on the passenger side fuse block. Checked good.... Did I miss something? Any help would be appreciated.
Steve
P.S. The rear hatch is not fully latching. Started around the same time. Will latch but not all the way. It locks, and the electric handle release works.
Old 01-12-2021 | 10:40 PM
Page 6-124 in your owner manual.
A Center High-Mounted Stoplamp Relay, and a Rear
Access Panel Door Interlock Relay (Panel Van only),
are located underhood in front of the left shock tower.
Check this relay.
Old 01-12-2021 | 11:25 PM
phoenix708's Avatar
I will check it tomorrow. Thanks for the info. Driving me nuts. Conflicting posts online about which fuse or relay, and locations. Frustrating.
Old 01-13-2021 | 07:55 AM
fuse #11 underhood should be vacant.
Not conflicting, changes between years/models.
Check the wires in the accordion conduit to the hatch. I bet the tag lights don't work.
Old 01-13-2021 | 11:05 AM
phoenix708's Avatar
OK, well good news......third brake light is fixed. Bad relay. Bad news.....still no cruise control. Light for switch on the steering wheel comes on but no cruise. Info, and return buttons work. Checked fuses #9, and #19. All good. Any ideas?????
Old 01-13-2021 | 11:32 AM
Other brake lights working? Is there a CEL light?
Old 01-13-2021 | 11:54 AM
phoenix708's Avatar
ALL brake lights are working. Marker lights work. Turn signals work. Someone had mentioned that the third light should blink when the hazards are turned on. It does not but it works with the brake pedal. Yes, I have a CEL light on. Checked codes. A couple of emission ones but it did have a "Trans Control Sys Malfunction." Code 0700. Car drives fine though. Ideas???
Old 01-13-2021 | 12:12 PM
Certain codes will disable the cruise control (safety feature).
3rd brake light does not flash with the hazards.
Fix the code issues and you should get the cruise back.
Old 01-13-2021 | 12:28 PM
phoenix708's Avatar
TKS, I will look into the code issues. Love the cryptic descriptions they give. Would be nice if it was a little warmer....hehehhe
Old 01-13-2021 | 12:31 PM
A. why not mention the codes? they are most likely the problem.
B. slight possibility; are ALL of the bulbs in the CHMSL working?
C. The wiring diagram shows the that the relay also goes to the TCM and the ECM. That is why the CHMSL ust be working for the cruise to work.
\Post the code numbers. We will gladly explain them.
Quick Reply: Third brake light not working
