Throttle body question
Old 01-19-2020 | 08:16 PM
Pedro J Saade's Avatar
Originally Posted by skyline26
stale thread but I have the same issue
cleaned my TB last night. Took off the air hose, left the maf sensor inside the intake tube (put it aside so i didnt get it sprayed with the TB cleaner) , unplugged TB, and removed it. Sprayed it with cleaner and wiped it clean while being gentle with the butterfly. I know some people have said to not remove it, but others have been ok with removing it and cleaning.
Well after reassembly, started up the car, rpms were high hitting 2500-3000. Let it run for a few minutes, came down a bit but not much. I then tried to follow the GM relearn process, which did not work since the rpms are still high. It is coming down slowly, finally at idle the rpms drop below 1000, but when driving and when i lift my foot off gas pedal, the rpms remain the same as if my foot is on the gas. Car drives it self. Also putting in neutral and revving up, the rpms take a few seconds for it to come down.
Did the relearn a couple times last night and this morning and still the same. It is getting better slowly with idle rpms but when driving the rpms stay up there as if cruise control is enganged.
any ideas?
thanks
hello fello HHR owners, so this is my first HHR but not my first car. I also have lots of experience building 2 stoke bike/motorcycles. Now for messing with the carburetor on a 2 stroke I've learned that you can mess with the butterfly improve your car's performance but because of my eccentric knowledge I'm getting reduced engine power correct me if I'm wrong but if you're getting more airflow it forces the vehicle to produce more gas giving you better performance so why is the computer taking so long to correct the butterfly. Another question do our computers get sent to GM's database or something when we know a little too much for our own good. They say you can't take the throttle apart well guess what boys I took the throttle apart and my engines running they say it's not even supposed to run. But I'm having the same problem several of you have had where if you touch a stuck throttle and you force it open it puts the air system on wack somehow I'm hoping I have the same luck some of you have where it will slowly resets itself cuz I also cannot afford a factory reset. But seriously these are smarter cars in the old days there has to be a manual format to reset my butterfly can someone please tell me how to do it not for GM but for an HHR. Because I've seen the GM video and I've done it for 2 days now I'm getting no results also I have used three different computers or whatever they're called to erase the codes they all say successfully erased but the check engine light is still on and when I run it through the database it tells me the same p 0 2 2 3. Not only that for some reason one of the computers was telling me something about fuel pump ground bad but yet no code was coming up for that and if my fuel pump ground is bad shouldn't my fuel pump not be working.
Old 01-19-2020 | 10:03 PM
Moved to a new thread
The computer strives to maintain a constant Air/Fuel ratio of 14.7:1. You can't do anything about it short of changing the computer firmware.
The computer measures the air flow and adjusts the injectors to keep the A/F at 14.7:1.
The throttle is electronically controlled. I don't know how you could drive with the electronic part disabled. Nobody ever said that you can't take it apart, just that it is not serviceable (they don;'t sell component parts).
If you tore it apart you broke it you need to get a new one. Used, they are cheap.
I'm sorry but I can't read the wall of words. I hope that answers the question. Erasing codes erases codes it does not fix anything.
P0223 means that the Throttle position sensor is reading a High voltage. This could happen if somehow the butterfly was held wide open while the key was turned on, or if it got stuck more than wide open or the sensor is broken in a more than wide open state. I don't have the time right now to research any more.
Posting the year, model and engine is helpful.
Old 01-20-2020 | 06:51 AM
If you force open the throttle body on an HHR you need a new one because you just broke it....
Old 01-20-2020 | 07:05 AM
Could be a loose connection, read causes and solutions, here
https://repairpal.com/obd-ii-code-p0223
as for the throttle body, if you took it apart , there is the problem, we get a discount from RockAuto.
Old 01-20-2020 | 09:11 PM
thank you for your reply and I have taken your advice since I cant get the computer to agree with my adjustments I found a throttle at a junk yard with the same gap I maid and some how it word and now 2008 hhr 2.2l runs like a SS. Wonder if taking it apart breached some kind of fail save to govern my speed.
Old 01-20-2020 | 10:43 PM
Casa Del Gatos's Avatar
No. Just, no.
Do you read what you write before you post it?
Old 01-20-2020 | 10:50 PM
No, you just broke it. THERE IS NO ADJUSTMENT. It is not a carburetor.
I suggest you study up on cars made this century before you start messing with electronic components. They have nothing in common with 2 stroke motor cycles.
Tearing thing up as a learning experience is great, if you can afford it.
Old 01-21-2020 | 05:33 PM
Blue_SS's Avatar
I vote for closing this before someone gets hurt... LOL OP seems happy.
Old 01-21-2020 | 05:54 PM
Silverfox's Avatar
Yikes.... You got my VOTE .......
Old 01-21-2020 | 08:09 PM
The ayes have it. Closed.
Quick Reply: Throttle body question
