Throttle stuck--OH MY!
Old 03-26-2013 | 11:11 PM
Originally Posted by speedwagen
For you old timers!
Ive got a moon pedal with a toe strap, left over from an old gasser, maybe that's the fix, along with a dead man throttle strap.
I just thought I would say something in case this starts showing up as a common occurrence among the tribe.
I remember the moon pedal with strap.. Not gonna be very effective on throttle by wire tho..
The dead man throttle strap may have possibilities..
Old 03-27-2013 | 05:55 AM
raffmanlt's Avatar
Originally Posted by IgottaWoody
Think that scares you..try the new B787 (airplane),,its almost ALL electric.....
and everything is written in engineer!
I was in the military so I believe in redundancy and a manual backup for everything. When we went to general quarters or close maneuvering - underway replenishment or coming into port we had men stationed at the rudders so if we lost steering they could take over manually.
Old 03-27-2013 | 12:36 PM
fastsuv's Avatar
There will be an error code stored only IF the computer thinks something abnormal occured.
I doubt you will have a code stored because if the computer thought the throttle was falsely open, it could have cut power by shutting off fuel to the injectors.
There may have been a mechanical pedal malfunction (for example the return spring on the pedal got stuck for some reason) in which case the computer would have no way of knowing the difference between that and you keeping the pedal down on purpose.
Steve
irmandy2
"How To" Tutorial Library
7
03-27-2014 11:28 PM
HHorange
2.4L Performance Tech
11
10-11-2009 10:24 PM
BC'SHHRS
2.2L Performance Tech
07-04-2007 07:14 AM
JT's HHR
06-29-2007 03:59 PM
Quick Reply: Throttle stuck--OH MY!
