Throwing Code P0128??
Ok, as you can tell, I am vehicle dumb, completely. I know that Ive read threads about this code but I dont understand. Anyways my car is throwing the code and I know that it has come up on a TSB....any comments, help??
Its reads around 180. Is it suppose to be low like around 45 when I start the car and go up? I actually watched it this morning, I guess Ive never watched before, dont know if thats normal. Oh and the check engine light went off today on my way home from work. So guess Ill see tomorrow...
PS: In this colder weather, allow some warm up time for the motor.. Otherwise it is more vulnerable to cause a gasket leak. When you get up to operating temps then "drive it like ya stole it" ...
Exactly sleeper, our aluminum intensive engines appreciate a gentle touch until warmed up, then you can flog them. That's true of any engine, get some heat in the motor before you ask it to produce its full potential, make that a habit and your engine will last a good long time.
