Time for a new engine!
#35
It’s worn a bit, see the ridge on the inner and outer edge, I’d have it resurfaced, much easier now while you have it out of the SS .
I’d also recommend you closely inspect the teeth on the ring gear , any wear from the starter bendix drive?
#38
RJ- When re-using the same flywheel, (before removal) I always mark it's orientation to the crank. So it can be re-installed in same position.
That flywheel looks to have some light hotspots, besides the wear.
#40
