Time for a new engine!
Old 03-20-2020 | 02:06 PM
  #61
dougcjohn's Avatar
Originally Posted by sleeper
Very True, I forgot about the Jeep & 4x4 guys.
We Jeepers use them to lift & swing the Ft or Rr over... out of a rut or trench.
Wobble and letting loose in the swing over is desired.
To me HiLifts are wobbly by nature... not considered a stable jack.
To me, very Brave to use as a supporting ridged jack... that setup would scare the heck out of me.
Especially when ya attempt to nudge a component inside of engine bay... moving anything would produce extreme pucker action!
Excellent job... very nice setup!
Old 03-20-2020 | 03:50 PM
  #62
Yes, it went up, rolled the powertrain under, and brought it back down onto the jack stands. Very carefully.
Old 03-20-2020 | 08:21 PM
  #63
Old 03-21-2020 | 10:59 PM
  #64
Well I put a few hours into the car today. Got everything done under the car. Suspension and steering is back together. All 4 on the ground now!
Still have to put the fuse block back together, and some small items like transferring airbox mounting studs, airbox, probably a few other things too.
It's supposed to rain for a few days starting in the morning. I worked hard to get the wheels back on, my hope was to push it nose into the garage door opening, and keep working while it rained. Who can guess what I discovered?
Old 03-22-2020 | 07:29 AM
  #65
In your rush you forgot something? Axles? A ground wire? A rad hose leaking?
I could guess on and on.
Old 03-22-2020 | 08:10 AM
  #66
Hmm. Wanted to push the car into the garage door opening. I'll assume that didn't happen because it would not roll ?
Go ahead and tell us. Don't make us guess what sort of Homer Simpson "Doh" moment you had.
Old 03-22-2020 | 09:08 AM
  #67
George guessed it. The steering wheel is locked, the key won't turn without power, so I can't unlock the steering. I was very disappointed. I should have expected it, but didn't.
So it rolls, but I can't roll it where I want to.
But now the forecast says I've got a few more hours until the rain. So if I can get my act together, I have a chance to get something done.
Old 03-22-2020 | 12:43 PM
  #68
I'm cleaning the intake-side catch can now. I've removed the turbo-side can for the time being.
Not too bad really, considering how much muck was flowing through recently.
Old 03-23-2020 | 08:30 PM
  #69
Old 03-23-2020 | 09:05 PM
  #70
RJ- Wow !! It is running ? That seemed really quick.
Quick Reply: Time for a new engine!
