Time for a new engine?
Old 06-29-2024 | 01:41 PM
Iwantadifferentcar's Avatar
I have a 2009 2.4 and lately I've been trying to fix issues as my paycheck allows. I knew it needed a timing chain kit after taking the valve cover off. I also noticed shavings as seen in the pics but my question is that I noticed openings under the vvt solenoids that I'm pretty sure shouldn't be there but I can't find anything when googling it so here I am.
Last edited by Iwantadifferentcar; 06-29-2024 at 01:46 PM. Reason: Didn't include all the info
Old 06-29-2024 | 02:11 PM
Apparently a neglected oil change schedule, a lot of crud in there, possibly a previous owner used cheap oil filters. You might clean it up with a Seafoam treatment or 2 . Those openings are supposed to be there.
Old 06-29-2024 | 02:49 PM
The openings at the very bottom are supposed to be there? They just felt really jagged and different from the ones on the side. I just want to make sure before I put more money into it.
Old 06-29-2024 | 03:16 PM
The P0017 indicates new chain and guides
The P0442 usually means your gas cap is loose. You should turn it until it clicks 3 times.
The other 2 are probably a wire or fuse
Old 06-29-2024 | 04:20 PM
That’s where the magic happens with the VVT solenoids!
Old 06-30-2024 | 09:35 AM
That's good to hear, hopefully I can get away with just changing the timing chain and guides. The car wasn't running horrible before I started taking it apart aside from some surging at idle and it shifting up and down where some gear changes are. I'll have to do some looking around and see what fuses/relays I need to swap out. But other than that I have been aware of the 3 clicks about the gas cap, I bought a new one earlier this year but I still keep getting that code. I did a smoke rest the other day and it seems to be coming from the air intake hose and one of the grommets on the bottom of my air box is cracked and not seating right and I saw smoke coming out of the bottom of that.
Old 06-30-2024 | 09:38 AM
Don’t worry about relays and fuses, just tighten the 4 bolts and firmly push in all the fuses and relays.
chevy1989
Mods - Exterior
12
07-31-2022 06:59 AM
HillsdaleHHR
04-08-2011 01:43 PM
garagebuilt
12
12-30-2008 10:40 AM
08BlkSS
09-27-2008 01:57 AM
Top Timmy
08-11-2008 03:01 PM
Quick Reply: Time for a new engine?
