Time to replace starter 07 HHR 2.4L?
Old 10-23-2013 | 11:13 AM
Originally Posted by bigwillyg
Well, it was definitely the starter. I pulled the old one out and the gear inside was sliding back and forth, and pieces of magnet/inductor were falling out slashing with what looked like a cover or shield that was cracked. Once I swapped it, the car started immediately. It drags now and seems to waste a bit more gas but it may be that my tires are low too. Would a p0341 obd2 code have anything to do with that?
http://www.obd-codes.com/p0341
here's a link for the code. Sounds like a CPS is either bad or poorly connected.
Starter should not drag, ever.
Old 01-10-2014 | 11:15 PM
bigwillyg's Avatar
Sorry for the late reply. The starter doesn't drag, the car does when I accelerate. I saw that one cause for this code I'd a bad starter (ironic since that actually had gone bad). This error code hasn't come back since I cleared it after replacing the starter. Should I replace the cps anyways?
Old 05-08-2014 | 08:24 AM
bigwillyg's Avatar
So, apparently my camshaft position actuator solenoid is what's failing. Although dealer fears possibly loose timing chain, my money is on the solenoid.
Old 05-08-2014 | 11:07 AM
The code of P0341 refers to the Crankshaft Position Sensor, not the Camshaft Actuator Solenoid (which would be typically indicated by a P0010/11 or P0013/14) - you might want to check into that a bit deeper.
Old 05-09-2014 | 07:32 PM
bigwillyg's Avatar
Yeah. I just had 2 ignition recalls done on my car and the check engine light and traction control light came on. The dealer scanned the codes and said it pointed to the solenoid. I'm gonna try that one first.
Old 05-09-2014 | 07:44 PM
  #26
What was the code? The code will point to the specific solenoid as per the how-to article on how to replace them: https://www.chevyhhr.net/forums/how-...13-14-a-28779/
Man, that is a great write-up!!!
Old 05-09-2014 | 10:53 PM
  #27
bigwillyg's Avatar
They didn't tell me what the code was, they just said they pulled it and it said the actuator solenoid was bad.
The Chevy dealer diagnosed it.
Old 05-10-2014 | 07:16 AM
  #28
Thing is, there is no THE there are two. Which one is bad?
Old 05-10-2014 | 10:40 PM
  #29
bigwillyg's Avatar
The intake side.
Old 05-10-2014 | 11:37 PM
  #30
1/2 hour job in the driveway - and $50 for the part and it be done. :)
Quick Reply: Time to replace starter 07 HHR 2.4L?
