Timing chain
Old 04-19-2020, 07:54 PM
guppy's Avatar
Timing chain
I found an HHR for sale that needs a timing chain. What are the odds that the engine is already damaged? How can I tell if valves and pistons have already collided or if it is really just a timing chain? I am hoping for an quick easy way to tell before I purchase, not try to remove the front cover and find top dead center in this guys driveway.
guppy is offline
Old 04-19-2020, 09:00 PM
Compression test & /or Leak down test.
sleeper is offline
Old 04-19-2020, 09:07 PM
I don't think there is an easy way.
If the chain has slipped, but is still on, the valves won't be fully closed when they should be. Compression and leak down tests will show leakage even if the valves aren't bent.
If the chain is off, you can't do a compression test. I guess you could remove the valve cover, and manually turn the camshafts to close the valves for the cylinders you would be leak down testing.
Not really a quick and easy test.
RJ_RS_SS_350 is offline
Old 04-20-2020, 06:21 AM
Scope through the spark plug holes, look for contact damage on the tops of the pistons.
Greybeard999 is offline
Old 04-20-2020, 06:33 AM
If the price is right, then you could just go ahead and buy it. Doing your own repair work ? Timing chain parts and extras will be a couple hundred $. If you have to replace the engine, $1000 or less should get you a good used one.
firemangeorge is offline
Old 04-20-2020, 07:52 AM
X2 for FMG’s suggestions, sometimes you have to roll the dice, and you’ll be lucky with just a chain replacement or not do lucky and drop in a used engine, if the body and rest of it is in great shape plunk in a new long block , and drive it!
Oldblue is online now
Old 04-20-2020, 11:23 AM
fastsuv's Avatar
How do you know it needs a timing chain?
I assume the seller is saying that it needs the chain.
If so, then did he say it needs it because it stopped running? Or because it set a code? Or because it was noisy?
The answer will go a long way to determining if there is engine damage.
Steve
fastsuv is offline
Old 04-20-2020, 08:57 PM
Steve
If they are truthful.. Just sayin....
sleeper is offline
Old 04-21-2020, 08:14 AM
A used car, not represented with complete honesty? Naw, never!!
Old 04-21-2020, 09:31 AM
fastsuv's Avatar
If the owner says it needs a chain because it sets the code or is noisy, then he should have no problem starting it up so you can hear it.
If he says it won't run, then I would assume there is some damage and needs a new engine.
Steve
fastsuv is offline
Quick Reply: Timing chain
