timing chain rattle again
Old 10-12-2019 | 03:58 PM
  #51
You need new chains and guides.
Old 10-12-2019 | 04:25 PM
  #52
It won’t, the chain is stretched or the front guide is worn or breaking.
Cloyes timing chain kit 9-4201SA
Cloyes balance shaft kit 9-4202S
RockAuto offers a discount code
https://www.chevyhhr.net/forums/supp...-2019-a-61707/
Old 10-12-2019 | 05:57 PM
  #53
himwestr's Avatar
I will get parts ordered, what can I do to keep this from happening again. I replaced all of these parts 30,000 miles ago.
Old 10-12-2019 | 06:47 PM
  #54
Would you get upset if I suggested taking it to a mechanic? You haven't mentioned any OBD2 codes, just a rattle sometimes.
A loose chain would set a CEL.
BTW, the front of the engine is the passenger side
Old 10-12-2019 | 06:59 PM
  #55
himwestr's Avatar
Not upset, looked at my post and I did not explain properly. I meant to say the part of the chain that is loose is toward the front of the car.
Old 10-12-2019 | 08:27 PM
  #56
NO Check Engine Light?
Old 10-12-2019 | 08:49 PM
  #57
himwestr's Avatar
No check engine light, just rattle at cold start sometimes.
Old 10-12-2019 | 09:38 PM
  #58
hen the rattle is probably something else like the air cleaner bracket is broken.
Old 10-12-2019 | 10:07 PM
  #59
himwestr's Avatar
So a loose timing chain will cause a check engine light?
Old 10-12-2019 | 10:20 PM
  #60
yes.
Quick Reply: timing chain rattle again
