Todays Dealership Visit
Took the HHR in for several thing's. First was the breaks pulsating. They installed new rotors. Second, Service engine light on. They ran there test's and found out the injector's need to be replaced. Paper work shows a 08-06-04-001 TSB to replace all 4 injector's. Third, lock up of ignition with key. Could not find any problem's. I asked if this happens again will GM pay to have HHR towed in, answer YES, let's hope so.
Can one of you Email me a copy of the TSB on the Shifter/Key letter??????
Has anyone seen this new TSB on the injector's ?????
Thank's
Thank's
They should have access to the TSB for the key getting stuck. If they claim to have never seen it, they must not service many HHRs or cobalts. Our dealer was well aware of the issue last year when we had ours in, and had multiple customers experience the same problem. Have them look again for the TSB or go to another dealer. Oh and I took a printout from this forum with the problem explanation and what others had done to fix it.
