Towing with a motorhome
We just got our HHR set up to tow behind our motorhome. the owners manual says you must pull the ignition switch fuse to prevent battery drain. We formally towed a Cavalier and did not have to do this. The dealer wasn't able to offer any explanation. It would seem that if the every thing is off (like radio's etc.) there would be minimal drain. Does anyone have any detail on this?
Pulling fuses may be a pain, but I would follow the manual. There is only 1 fuse to pull and I think it is number 8 but I am not looking at the manual or the HHR right now. I leave the little fuse puller attached to it all the time so it is easy to pull and replace. I have pullled mine for about 4000 miles so far and have had no problems. On my 98 Malibu you had to pull 4 fuses, so I think 1 is a better deal.
Tikker
24
07-20-2018 03:23 PM
