tpms help
Old 02-25-2015 | 12:03 AM
Chevyhhrfan's Avatar
Cool tpms help
My battery died . When i charged it back up it knocked out the tpms and my key fob. Had my key fob rekeyed. Took it in to relearn the tpms. No faults with the sensors with will not read on the dash the tire pressure. The dealership want $90 an hour to look for the problem. Please help me got some answere and fixs
New to the hhr forums. seems like a lot of how to here i glad i found the site..
Old 02-25-2015 | 06:38 AM
Lucky's Avatar
Welcome to the site
I see you have an 08 so I would bet this is your problem. Sadly the dealer is the only one that can perform this repair.
#08-03-16-001B: Key Fobs Inoperative, TPM System Not Reading Correctly - Dashes on Al Four Tire Readings, DTCs C0775, C0569, B3105 Set, Unable to Program TPM Sensors (Reprogram RCDLR) - (Jul 31, 2008)
Subject: Key Fobs Inoperative, TPM System Not Reading Correctly - Dashes On All Four Tire Readings, DTCs C0775, C0569, B3105 Set, Unable to Program TPM Sensors (Reprogram RCDLR)
Models: 2008 Chevrolet Cobalt, HHR, Malibu
2008 Pontiac G5, G6, Solstice
2008 Saturn AURA, SKY
This bulletin is being revised to update the Important statement to reflect the new direction to no longer contact TCSC. Please discard Corporate Bulletin Number 08-03-16-001A (Section 03 - Suspension).
Condition
Some customers may comment that the key fobs are inoperative or that the TPM system is showing dashes as the reading for all four tires.
Technicians may find DTCs C0775, C0569 and B3105 set simultaneously in the RCDLR module.
In addition, the technicians may find Tire Pressure Monitoring sensors are unable to be programmed to the vehicle by adding or releasing pressure to the tire while the vehicles in the TPM learn mode.
Cause
These conditions may be caused by the following:
• The RCDLR may lose its transmitter and tire pressure monitoring data from its memory if a low voltage condition occurs on the vehicle.
• The ability for TPM learning by adding or releasing pressure to the tire has been disabled in the RCDLR.
Correction
Reprogram the RCDLR with an updated software calibration to address both issues listed above. This new service calibration is available on TIS2WEB using Service Programming System (SPS). As always, make sure your Tech 2® is updated with the latest software.
Important: If the Tech 2® could not establish communication with the RCDLR AND the programming event ended with error, attempt to reprogram in Service Programming System (SPS) by selecting "Remote Control Door Lock Receiver (TSB 08-03-16-001) with E4399 error -- Pass Thru Only".
Once the RCDLR module has been reflashed with the latest software and calibrations, the following may also be necessary:
• Relearn all keyless entry transmitters.
• Reconfigure the tire pressure placards and the tire type.
• Relearn the tire pressure sensors.
Refer to SI for the procedures to relearn transmitters, placard and tire type configuration and tire pressure sensor learn.
Old 02-25-2015 | 07:13 AM
I don't know exactly what "Had my key fob rekeyed" means?
Can you do the TPMS position relearn procedure? If you need to have the dealer reload the firmware, be sure they get that part working.
Out of curiosity, how long was the battery completely dead? It should take many days for the stay alive memory to completely drain.
Old 02-25-2015 | 08:26 AM
Please let us know your results, from that bulletin and the reflash.
donbrew
10-30-2018 11:32 AM
gerrbear
Tires & Wheels
09-26-2012 05:53 PM
BlackknighT
08-19-2011 08:15 PM
sumo1
07-18-2009 08:46 PM
Lil Cheney
02-19-2009 09:04 AM
