TPMS problem
Old 03-17-2015 | 03:37 PM
vulture07's Avatar
TPMS problem
Hey yall I have an 08 Panel and recently when I got in and cranked it the low tire pressure light came on. I got out and looked at the tires and immediately drove it up to my garage to check the pressure. All four tires read exactly the same give or take a 1/2 pound. The dash reading says I have 34 lbs in all the tires except the right front and it reads 25lbs. Could this be just a bad sensor ?
Old 03-17-2015 | 03:46 PM
Yes it could.
You can try deflating and refilling the tire and then see what the tpms system says.
Old 03-17-2015 | 07:56 PM
Lucky's Avatar
Sounds like a faulty tpm sensor. Most of the time they stop reading all together instead of just reading wrong.
Has anyone ever put fix a flat in the tire? I have seen that mess up a few.
Also if you decide to replace the sensor make sure that the relearn procedure was done the last time the tires were rotated or moved from one position to another.
I mention this because if the car was serviced and the tech did not put a wheel back on the same position no one will know until you try to fill a low tire indicated by the dash.
sense the relearn was not done your adjusting or replacing the wrong sensor.
Old 03-18-2015 | 11:28 AM
I have used both "original" and "sensor safe" fix a flat with no harm being done.
But there are warnings on the can that I ignored.
I am suspecting human error since one is reading 25. Either getting the reading or in the position resetting.
I seem to recall the warning comes on at like 8 PSI difference from each other.
Old 03-18-2015 | 03:30 PM
Blue_SS's Avatar
You ARE good. 8 PSI difference is correct (to my limited knowledge) too, and whomever said that "the sensors usually just fail" is also correct.
OP, another "long-shot" issue is, if the light is intermittent, it could be picking up a sensor from another nearby vehicle. It's possible, if not all that likely. IF it "only happens at home", or something similar, consider this...
Deke40
Tires & Wheels
08-05-2012 03:29 PM
mitzkity
Maintenance and Upkeep
11-03-2011 09:40 AM
BlackknighT
08-19-2011 08:15 PM
urbexHHR
11-03-2010 08:00 AM
HHROwner
05-29-2009 05:47 PM
