Traction Control light
Old 11-22-2010 | 12:16 PM
lorira's Avatar
Has anybody else had an issue with the TC light go on when driving on the highway. Then while the light is still on driving on city streets the transmission slams while changing gears. If I turn off the engine and wait 15 minutes, everything is fine.
Old 11-22-2010 | 12:20 PM
That's "limp mode"..... are you getting a check engine light?
Old 11-22-2010 | 05:34 PM
jay loukakis's Avatar
there is a thread more than 10,000 hits, codes po110 and po1011 changed the cam solenoids solved the problum,
Old 11-22-2010 | 06:47 PM
BlackknighT's Avatar
By the way... Welcome & you'll be back to enjoying your ride soon!
Old 11-23-2010 | 04:29 AM
Hopefully you will get an error code from the CEL - if the code is P0013 or P0014 the problem will be due to one of the Camshaft Postition Actuator Solenoids. Here is a link to the process to replace them - https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/
Cost of both solenoids is ~$100-$150 - and is a pretty simple job to replace (<1 hour).
Old 06-17-2011 | 12:39 AM
pobryne's Avatar
I got this P0014 code today, checked the code listing on autozone and it said add or change oil or the solenoid. Added a quart and the code went away. Changing the oil tomorrow.... The 10,000 mile oil change for this car is BS... I got 142,000 miles gonna change it every 3,000 from now on.
Old 06-17-2011 | 04:22 AM
The oil life reading on the DIC doesn't track oil amount.... You still need to check the dip stick. Not sure where you got the 10,000 mile number from, I don't think anyone stated "Ignore oil for 10K and then change it"..... Last change I got 7704 with 20% still reading on the DIC, I use full synthetic Pennzoil and check the oil when I fill up, just like the old days. No problems here.
purple people eater
09-17-2016 01:07 PM
tubejock
Drivetrain (Excluding Engine)
18
12-18-2015 11:08 AM
tessdan
11-05-2014 06:16 AM
tmjackson
04-23-2014 08:27 PM
bobnj
06-13-2013 05:17 PM
Quick Reply: Traction Control light
