Traction control light always off
Old 10-29-2021 | 12:11 AM
janoka's Avatar
2009 HHR LT1 2.2L, bought recently.
I was trying to familiarize myself with the car and noticed that pushing the ESC/TCS button did nothing. So I checked the warning lights before starting the engine and sure enough, they all illuminate except for the Stabilitrak/TCS Off warning light (rightmost), it remains dark.
I thought for a while that perhaps the warning light itself may be defective but checking the manual I noticed that pushing the ESC/TCS button should display the TRACTION OFF or ESC OFF message in addition to the warning light but there are no messages on the DIC.
Also, I connected an OBD2 reader and there are no trouble codes that would indicate any problems with the stability control system.
What could be happening? Could a prior owner have done something to the car to result in this behavior? Obviously when snow comes I'll find out if I have a working traction control system but I'm curious if anybody has any ideas what could be going on. I couldn't find any comparable problems on the net.
Old 10-29-2021 | 07:32 AM
Could be a loose relay or fuse.
Old 10-29-2021 | 07:33 AM
Radco's Avatar
First WELCOME to the group!
The gear heads will chime in soon , But I would start with the checking the fuse. .. And no I do not know what fuse it is lol. So I will be following and hopefully yo get a answer soon ! Please update what you do find out
Old 10-29-2021 | 07:35 AM
Radco's Avatar
Steve I looked at the fuse box diagram and did not see Traction Control . I am curious now lol
Old 10-29-2021 | 08:32 AM
According to another thread ,these fuses and relays
fuses #44, #57, #61 underhood fuse box.
Ground is at G111. https://www.chevyhhr.net/forums/how-...cations-56504/
Thanks to Donbrew’s contribution to this information.
https://fusecheck.com/chevrolet/chev...1-fuse-diagram
Old 10-29-2021 | 09:13 AM
How about the seat belt light? Do you have a fog light switch?
I'm thinking somebody either unplugged the button or switched the plugs since a few plugs are alike.
To remove the "waterfall" stick your fingers into the AC vents and give a sharp pull, then you can see the back of the switches and lights.
Old 10-29-2021 | 09:46 AM
Great suggestion, I seem to remember someone mixed up a connector a long while ago.
Here in post #4
https://www.chevyhhr.net/forums/gene...ts-stay-59364/
Old 10-29-2021 | 09:58 PM
janoka's Avatar
I have a fog light switch, it works, and the fog light control lamp works too.
The seatbelt light works as well. I didn't think it was the switch anyway since the traction control light does not turn on after turning the ignition key.
I'll check the fuse box under the hood tomorrow.
Old 10-29-2021 | 10:35 PM
What about the hazard lights?
Fu8ses #6, #44, #57 and #61 in the under hood fuse box need to be checked.
Old 10-30-2021 | 10:43 PM
janoka's Avatar
Those 4 fuses are fine. Hazard lights work, as well as the green left-right arrow control lights for them.
Thx to everyone trying to help. I guess I'll wait for the winter to test the ABS and traction control and if either doesn't work, I'll just take the car to the shop. If they do work, I'll resign to the fact I don't have a warning light for TC and that I won't be able to turn it off.
scubanut
27
07-09-2024 10:51 PM
Eric Overmiller
03-22-2018 11:07 PM
Alexwsilver2010
08-09-2014 11:41 AM
lzrdking
07-30-2008 03:10 AM
DukeofWagner
06-18-2008 09:47 PM
