Transmission Fluid Leak
Old 11-07-2020 | 11:23 AM
pandalocksmith's Avatar
im getting a transmission fluid leak. added 3 quarts and its coming out of the pan. Looks like the gasket from the transmission pan blew, BUT it also looks like its coming from above the pan somewhere. can someone look at this video and tell me what they think also went bad? thankyou.
link to video:
thank you
Old 11-07-2020 | 02:05 PM
It appears to be coming from the starter area, are you sure it’s transmission fluid, engine oil could be leaking out of the oil pressure sending unit, or it could be the torque converter seal, if it is in fact transmission fluid
Old 11-07-2020 | 03:35 PM
Lonwane's Avatar
I'm on agreement with Oldblue. That does not look like tranny fluid.
It may be the oil pressure sending unit as the starter looks wet.
These tend to be a failure point but I have never seen one leak like that.
Please post year and engine size for further evaluations.
The transmision pan looks to be covered in residue from a different leak.
Old 11-07-2020 | 03:45 PM
im pretty sure its tranny fluid but im no expert. my symptoms prior to this happening were the car would barely move after driving for more than 40 mins....when cold it would run fine. was driving the other day and it was running weak but i pressed it until i got home. smoke was coming from under the car. next day, i added 3 quarts of tranny fluid, turned on the car and looked underneath and thats what i saw. also it smelled like that steering fluid smell.
Old 11-07-2020 | 03:51 PM
also, its a 2006.not sure about the engine size.
Old 11-07-2020 | 04:23 PM
You have probably grossly overfilled the transmission.
Old 11-07-2020 | 05:31 PM
ATF is reddish and fairly thin. Motor oil is black and not so thin. If you blindly poured 3 quarts into the trans you did overfill and probably blew a seal.
Old 11-07-2020 | 08:07 PM
Where did you pour the 3 quarts into? The fill hole on the transmission is hard to get to without a long thin funnel.
Old 11-07-2020 | 10:31 PM
Looks like engine oil to me.
If the transmission fluid was that dark, it's burnt. If the fluid was burned up that bad, the transmission would most likely be shot.
Note: Check the oil filter cap. It may be cracked or loose. Anyone change the oil filter recently ?
Old 11-11-2020 | 06:19 AM
I guess the OP isn't coming back. Another One and Done poster ?
Since his bio says he's 107 years old , I think he forgot he posted here................
