Transmission Problems
Old 03-02-2009, 09:49 PM
NxlKing2304's Avatar
Question Transmission Problems
Wondering if anybody has had any problems with their transmission. I just had a trans flush one,. and now only when the engine is cold, The engine Surges when i come to a stop, while braking that is. sometimes immediately a few seconds after coming to a complete stop.
Then sometimes I have problems with it shifting. it doesn't downshift properly sometimes, and revs very high. I have to take foot off gas and wait for it to chang and then go again. Ideas?
NxlKing2304 is offline
Old 03-02-2009, 10:07 PM
GTOMIKE's Avatar
Ideas?
They did not put the right amount back in
GTOMIKE is offline
Old 03-02-2009, 10:15 PM
nice, would that cause the surges too?
Old 03-03-2009, 06:39 AM
hhrcrafty's Avatar
Yes, especially when cold. Why did you have the transmission flushed? The fluid is good for the life of the car unless it starts leaking.
hhrcrafty is offline
Old 03-03-2009, 07:09 AM
well, I was told several times by different dealers to change at 50K? I can't stand dealers, they lie. Most of them anyway!
Old 03-03-2009, 05:34 PM
hhrcrafty's Avatar
Nah. The car doesn't even have a dipstick, so how would they have "flushed" the transmission when their flushing equipment is incompatible with the unit? Probably drained, filled, and didn't do it right.
Old 03-03-2009, 05:41 PM
cc732's Avatar
Who did the tranny flush and why? If there wasn't a problem before the flush why was it done?
cc732 is offline
Old 03-03-2009, 09:52 PM
I was told by several dealers this was a 50K maintenance thing.
Old 03-03-2009, 10:12 PM
GRUMPEE's Avatar
2006 manual calls for change tranny fluid/filter (severe service only) @ 50k mi
(h) Change automatic transaxle fluid and filter if the
vehicle is mainly driven under one or more of these
conditions:
− In heavy city traffic where the outside temperature
regularly reaches 90°F (32°C) or higher.
− In hilly or mountainous terrain.
− When doing frequent trailer towing.
− Uses such as found in taxi, police, or
delivery service.
If you do not use your vehicle under any of these
conditions, the fluid and filter do not require changing.
GRUMPEE is offline
Old 03-10-2009, 05:57 PM
cc732's Avatar
I was informed that an oil change would not be necessary if the car was used as Grumpee has described. Dexron 6 is quite durable and since the unit has no dipstick, oil changes would be rare. However, in your case, I suspect a generic inferior oil has been used in place of the Dexron 6.
Clare
cc732 is offline
Quick Reply: Transmission Problems
