Transmission problems...
Old 03-29-2012, 09:21 AM
Doog47's Avatar
Just wondering if any of you guys have had the same problem that im having..Im getting like a clunk noise everytime my transmission goes through the gears..Its not happening everytime just once in awhile..Any imput would be great...My hhr has about 60000 miles on it..07
Doog47 is offline
Old 03-29-2012, 01:03 PM
Is this a harsh sound followed by the transmission "banging" into the next gear, or is it more of a "thump" as it shifts?
843de is offline
Old 03-30-2012, 06:31 AM
Doog47's Avatar
Its more of a thump..or a slight kick..and then my engine light goes on for a bit then shuts of and it repeats every so often...
Doog47 is offline
Old 03-30-2012, 06:59 AM
no issues yet , but I'll pay more attention to it, in my 07 with 94,000 miles. I think I need to change my trans filter and fluid, I skipped that step awhile ago!!
Oldblue is offline
Old 03-30-2012, 10:32 AM
OK, take it to your local auto parts store like Advance or Autozone and have them pull the codes(its free), then post them up here, it sounds like you may have a problem with the TCM(Transmission Control Module)or something else electronic.
843de is offline
Old 03-30-2012, 12:05 PM
us11csalyer's Avatar
maybe vacuum leak or vacuum valve?
us11csalyer is offline
Old 03-30-2012, 12:08 PM
The 4T-45E transmission is all electronically controlled, long gone are the days of the vacuum modulators, there are a couple of different possibilities here but until Doog47 gets the codes pulled...it would just be guessing.
843de is offline
Old 03-30-2012, 12:23 PM
jtwrace's Avatar
My '09 with a 2.4L blew the trans up wtih 49k mls. It was so bad it cracked the case. Gm reps arrived too. I do normal highway driving at 120 mls per day. Second one seems to be better with 50k on it now. I brought it in for surging and they told me the cam phasers are bad. Flushed the trans....
fingers crossed
jtwrace is offline
Old 03-30-2012, 12:32 PM
Doog47's Avatar
Im also having trouble with my steering colunm..The thing raddles like a son of a ***** when im coming to a stop...Took it in to the shop a little while ago and they said they couldent find the problem and now its worse then before...
Doog47 is offline
Old 03-30-2012, 12:40 PM
Snoopy's Avatar
When you say, "shop" do you mean an independent auto repair or a GM Dealer?
A dealer should rapidly recognize a steering column problem. Canadian GM Dealers were issued a recall for the column. However, you MAY be to late for this, if it wasn't done already.
In any event they should know what the problem is.
Snoopy is offline
Quick Reply: Transmission problems...
