Transmission Troubles?
Old 01-25-2008 | 05:17 PM
Alzonie's Avatar
Originally Posted by Goose
You guys notice that the drivetrain sounds very noisy when it is old out and just starting out? Almost like a whine..is this something all GM trannys exhibit?
Goose
I've noticed the same thing with ours when first starting out on a cold Morning. (Cold here being 35 degrees or so!) But within a couple of miles or so the "Whine" goes away and it's shifting just fine.
Old 01-26-2008 | 09:39 AM
hhrcrafty's Avatar
The older design GM transmissions are pretty loud when cold like that. The internal pump has to work pretty hard to get the pressure up in that cold fluid.
Old 01-26-2008 | 04:51 PM
Alzonie's Avatar
Do you mean the tranny in an '06 HHR is an "old" design??
Old 01-26-2008 | 05:57 PM
Black Rose's Avatar
The transmissions in a lot of GM FWD vehicles are "old" designs. If it's not broken, don't fix it.
Old 01-27-2008 | 09:25 AM
cc732's Avatar
"Old" Design?
The 4T/45E is one of the "newer" programmable transmissions.
I haven't had the opportunity to investigate the "newer" 6 speed FWD (re: 2008 Malibu LTZ) yet.
GMPT & Windsor Trans., make a lot of "upgrades" of both software and hardware as model years progress.
Clare
randilynn
10-21-2014 11:46 AM
slksly
03-10-2014 07:13 PM
Galaxie500XL
06-27-2010 09:59 PM
Packerfan84
11-26-2007 08:27 PM
HonestBlues
02-07-2007 07:28 AM
Quick Reply: Transmission Troubles?
