turn signal cancel dosent work
Old 10-13-2012 | 03:01 PM
my first pannel's Avatar
im new here i have just bought an 08 pannel 2.4 auto trans
is this a comon problem (will it be just a switch ?) and is there any others i should look for with the hhr ?
i am prety happy with it so far (wanted one of these since they came out) thanks
Old 10-13-2012 | 03:06 PM
Welcome to the site, Panels rule !!
Old 10-13-2012 | 03:24 PM
VinceP's Avatar
Welcome to the sight.
The turn signal has been an issue for some. There is actually a write up for hop to do a repair on it. There is also a thread that lists the so called common problems for the HHR. A quick search will find them.
Old 10-13-2012 | 04:18 PM
ChevyMgr's Avatar
This thread will tell you what is the most common cause and how the OP fixed it.
https://www.chevyhhr.net/forums/how-tutorial-library-21/turn-signal-canceling-failure-fix-lots-pics-37992/
Old 10-13-2012 | 04:27 PM
thanks for the replys i did find the repair thread (after i tried the search 2nd time) good rite up and the u tube vid too !
the po got me on that one
now i read someware that you can disable the tire presure light ?
unique_w
"How To" Tutorial Library
48
05-09-2016 07:32 AM
g bonnes
09-02-2015 07:04 AM
busteam1
08-02-2010 02:54 PM
RkyMtnHHR
11-20-2009 08:15 PM
1Panel2NV
15
06-19-2008 03:15 PM
Quick Reply: turn signal cancel dosent work
