Ummm wheres the SS's battery?
the battery is in a great spot, unless you are hit really hard from behind(battery acid could be a spray issue) but then again, if you are hit that hard from behind battery acid is the least of your worries...... another possible issue-- punctured gas tank near main electrical connections.
But it was a late 96, & battery was in the trunk, like the 1997s' came.... That was a surprise !!!
What a car tho.. Had that one for 10 yrs..
