Underhood Fuses Tip
#32
Originally Posted by yeshua63043
Are there any placed elsewhere that should be checked?
Also there is a 50A fuse on the batttery terminal (under rear storage compartment), that feeds the front fuseboxes.
Check to make sure it is seated fully so that you don't experience any intermittent electrical problems.
Hope it helps,
#38
Thought it was time to BUMP this one.
For all the new owners....check your underhood fuses. Chances are pretty good all or most are not set well.
When we got Bonnie's, I had the salesman open the hood on a few other HHR's they had, 3 of 4 had loose fuses under the hood!
#40
Originally Posted by jx3
Isn't that the reason it has been made a "stickie", so it doesn't get buried?
