Update: Outside air temp read problem
Old 08-19-2006, 08:21 PM
Over50's Avatar
The problem of my outside air temp indicator staying at one temp for long periods of time has been resolved - at least so far. It took trying (3) different what the dealer called a BCM (body control module) before they got one that would work. Chevy was assisting them during the process, so for others having the same issue, Chevy can't say it hasn't heard of the problem. Anyway, just thought I'd pass this on FWIW.
Over50 is offline
Old 08-22-2006, 11:27 AM
GCarp's Avatar
My outside air temp indicator seems to work fine until the outside temp gets above ~90F. Then it seems to climb faster than the actual outside temp. So when it gets to be about 90F it is reading about 95F and @ 95F it is reading about 105F. I was told by the dealer he couldn't find anything wrong - that it was working properly ("Working to design specs"). It was only about 85F when he checked it though. What good is having an outside temp ind. if it doesn't read properly ?
GMC
GCarp is offline
Old 08-27-2006, 01:27 PM
GhstRider's Avatar
I had a problem with mine but opposite. It was reading 57F degrees when in reality it was about 94F degrees. It was stuck at 57F degrees for about 4-5 hours. Then out of no where it works just fine. Maybe it was after I checked the fuse block for loose fuse. There was no loose fuses by the way.
GhstRider is offline
Old 08-27-2006, 09:48 PM
booksmitty's Avatar
Mine has done the same thing since I've had it, 24K mi. But I've never asked about it.
booksmitty is offline
Old 08-27-2006, 11:27 PM
GhstRider's Avatar
It works now...
Where is the sensor located in the car? Is it that bubble thing in the middle of the dash?
Old 08-27-2006, 11:38 PM
Wackaloon's Avatar
Nope, the bubble thing on the dash is the sensor for the auto lights.
Wackaloon is offline
Old 08-27-2006, 11:39 PM
GhstRider's Avatar
So where is the sensor? Thanks for answering another question I was going to ask!
Old 08-28-2006, 12:21 AM
HHR DLYT's Avatar
The temperature sensor is on the passenger side behind the headlight on the core support.
Hope that helps
HHR DLYT is offline
Old 03-07-2007, 11:11 PM
viknguy's Avatar
Hey OVER50 Did the dealer have the BCM's in stock. I'am taking mine in Thursday for the same problem
viknguy is offline
Old 03-07-2007, 11:37 PM
I have a feeling he's not around anymore. He posted this about a year ago. His last post was 6 months ago.
GDZHHR is offline
Quick Reply: Update: Outside air temp read problem
