vacuum leak
Old 12-11-2019 | 04:27 PM
  #51
UnknownError's Avatar
The too rich code has been intermittent, and the last time I checked the codes it wasn't there, but a cylinder 4 misfire was.. sigh.. I already replaced the spark plugs, new injectors, swapped the coil pack. I thought maybe working on the manifold I was crushing the wires that go to the coil pack, so I put some electrical tape on there where the tubing cracked away and could make contact with the valve cover
Old 12-11-2019 | 04:38 PM
  #52
Did you do a compression test? I really don't feel like going back 5 pages.
Old 01-07-2020 | 02:28 PM
  #53
Update
Just wanted to update that I had installed a new flange gasket on the manifold to exhaust and have driven over 1k miles without getting a fault code for running rich. I have not fixed the stud or bolt so if it is leaking it's not enough to pop a code. My fuel trims are better but still not ideal but that's okay as long as the code and hard shifting are gone all is well. Thanks to all help from everyone.
cllwyrc1
2.4L Performance Tech
11
05-29-2017 11:52 AM
anth3388
12-10-2015 12:39 PM
promod62
11-12-2014 05:50 AM
Mike Yeager
04-04-2013 10:22 PM
Lee3333
08-01-2006 11:49 PM
Quick Reply: vacuum leak
