Valve cover bolt tightening sequence
I am about to replace valve cover gasket on my HHR. What would be correct valve cover bolt tightening sequence?
It seems that every manufacturer has a different pattern, but the principle is the same. Go from center and move outward.
Pattern adopted to Ecotec 2.2 valve cover from another manufacturer.
Another approach:
Another approach:
What you have labelled as 12,13,14, and 15 are actually the hold-down bolts for the ignition coils for each plug. They do not hold down the cover.
If I remember correctly, the bolts for the cover only go down so far before hitting a shoulder so they can't squeeze the cover too much.
I generally use a "spiraling outward" sequence that starts in the center of the cover and spirals outward, to force any cover deflection outward. In this case I don't think it's overly critical.
Steve
Steve
I would not put any thought at all into that. They barely torque and that is to avoid cracking the cover. 89 lb. INCH That is just snug using a 1/4 drive handle, not even compressing the rubber under the bolt head.
Steve
Steve
