Valve cover installation help 06 2.4
#31
Valve
It has gotten better iv thought about running some restore in it or marvel mystery oil have had luck n past or oldman I kno said run diesel fuel through it would help to so idk I'm taking it one step at a time
#32
If you were serious about running diesel, I would only add 1 qt, with the rest using oil.
And this would only be a short around the block kinda trip, & drain as quick asd you could upon return.
Driving any further risks wiping out the bearings.
#33
Oil
Yea I'm not so sure about diesel myself I'm gonna drive another six hundred miles or so n change it again see if it starts sucking oil again its trashed up inside I'm sure have a oil catch on it to right now still smoke only at idle gonna try a flush I think
#37
It can tell one if it's the guides, or the rings. You just have to listen during the testing.
#39
Curious as to the why, when the guides are not in the combustion chamber? If loose guides cause leakage past the valves, how would you know it was guides, and not seat mating surface?
