Warning Bell
Old 06-27-2011 | 10:51 AM
Rikki Sixx's Avatar
Warning Bell
The little "dinging" that happens when the seat belt is not hooked up or when the keys are in the ignition with the door open no longer sounds on my 2008 Panel. Is this an easy fix? Cuz I'm off warranty.
Old 06-27-2011 | 11:06 AM
You may have an issue with the chime/ding volume being turned down all the way(somehow), give this thread a read and it may point you in the right direction.
https://www.chevyhhr.net/forums/problems-service-repairs-42/adjusting-headlight-door-key-chime-volume-15860/#post365214
Old 06-27-2011 | 01:05 PM
Rikki Sixx's Avatar
Thanks for the reply. I performed the steps as indicated in the thread and the chime does sound when I adjust the volume so I know the chime works. However, my original problem still persists.
Old 06-27-2011 | 01:15 PM
Silverfox's Avatar
Theres times when I would consider it a blessing.
The things like a nagging wife.
Old 06-27-2011 | 09:43 PM
Lucky's Avatar
You can try disconnecting the battery for a few min. It's like rebooting the system. can't hurt to try
1970judge
03-11-2011 02:32 PM
Jeff®
01-06-2009 08:11 AM
Beaux66
11-30-2006 07:25 AM
john_a_basilio
11-24-2006 03:15 AM
jmhopk
10-29-2006 12:01 AM
