Warranty Issue on antifreeze?
I had a 99 Silverado w/dex cool and after a few yrs it began to turn brownish. Read that there were a lot of problems at that time. Also have an 02 Impala with it and it seems to be fine (time to change it since the time limit is up)
I hope GM has solved the earlier problems
Technically the coolant issue would have been the lower intake manifold gasket failure problem that plagued those engines. Even my 2003 Malibu (I was a sucker for punishment) had the lower intake manifold gasket failure early on in it's life.
Antifrezze Change
I had a '96 GMC Jimmy V6, 10* outside and I had steam coming out from under the hood. Only had 42,000 miles on it. Took it to the dealer and had it power flushed and refill with the old stuff.
I had to pick up the bill, and was told it would not void the rest of the warranty.
Also had a similar problem with a 2001 Chevy Blaser S10 with V6 and 56,000 miles. This time I drained it out and bought a power flush tool kit. Once again I installed the good old stuff.
Properly maintained, and a Dex Cool system will out last a normal antifreeze.
Key is, maintain. Most completely ignor the cooling system until something happens.
It will void your warranty to switch it out.
HHRcheater.....
Can I ask which engines AND what year, make of vehicle they were in????
I have some LIMITED knowledge reagarding the previous warranty issues and DEX-COOL. You do realize.......
the formulation of the present Dex-Cool is completely different since those problems (probably because of those problems).
the Dex-Cool....cooling sludge/engine failure problem.....was limited to certain types of engines (other vehicles, in the GM product line, experienced no problems with Dex-Cool.
I would suggest, because of the design and components of this engine, you have nothing to worry about. Especially since the formulation is different.
You do what you think is right. But as a warning, the entire change of the type of coolant specified COULD void any related warranty issues. From simple but expensive things like radiators, water pumps, to heads, valves, and entire engines.
Oh, and as I mentioned some time ago (in a related thread), I was one of the field test vehicles (personal vehicle) for Dex-Cool. Have had it in EVERY car since then...never experienced a problem OF ANY KIND>
Antifreze Change
Just to set the record stright, I do all my own repairs. Why would I pay another mechanic when thats what I do to make ends meet.
Yes it has the 4.3 V6 in it. I checked with my ex shop leader on warranty coverage by switching coolant's. He seems to think he saw a memo on just this.
I'll get back to all ASP.
