Water in the Driverside Front
Hey, if this has been posted please link a thread into this post.
Basically I noticed this morning in the footwell of the driverside of the car water sepage and it was just starting. I drove to work in the rain and never noticed anything until I got to work.
I know there is a thread about the passangerside but being the driver, I need to know if its a draining issue or what.
The car is a 2007 HHR LT with a lil over 55k miles.
Let me know what you think.
Thanks.
Thanks.
The answer is yes I have and nothing I have seen shows the issue that I have. The car never had an issue like this but I can check the sun roof channels, the cowl butyl patch, and if anyone else has an observation on actually fixing the problem. Let me know.
Also....
https://www.chevyhhr.net/forums/show...ght=WATER+LEAK
Go yell at this guy becuase he seemed to ask the same questions about the passanger side which has been covered 100 times. Where as my driver side issue seems to be unique.
Not being a jerk but since this site is not as active as bigger sites often I find myself combing through 1-5 year old posts with no obvious updates.... just saying.
Also....
Well, if you had done a search, it would have been helpful if you had said that. Just sayin.
There are several posts about drivers side leaks, and I expect that one of them may point you in the right direction.
Also....
Also....
Where in Ct.? I from Stratford originally
Rich
Hope these help!
Check this link
https://www.chevyhhr.net/forums/show...ak+driver+side ( leak at windshield )
Also....
Go yell at this guy becuase he seemed to ask the same questions about the passanger side which has been covered 100 times. Where as my driver side issue seems to be unique.Not being a jerk but since this site is not as active as bigger sites often I find myself combing through 1-5 year old posts with no obvious updates.... just saying.
Also....
As far as your leak. I would get out the garden hose and start looking for your own leak area. It could be several possibilities and the garden hose method should help you locate it.
Well thanks to those who actually contributed.
As earlier stated its a 2007 that DOES NOT have the Butyal Patch so i got the cowl off and verified, im working with the garden hose method now, most if not all post point to earlier production cars.
Thanks.
Thanks.
Really sorry to hear about your water leak. I can do more research for you and see what options you may have available. Just private message me your name, address, vehicle identification number, and current mileage.
Thanks,
Jessica L.
Chevrolet Customer Care
Hey I think I fixed it. The passenger side drain was clogged and I think the water travelled to the driver side. I ran water in each hole and no further issues. I peeled back the carpet to monitor. Nothing came through. Hey thanks for the help I'll monitor and keep u posted.
