Water in floor pass side ???
Had a fairly heavy rain the other day, Pass side floor had a lot of water, looked at weatherstrip around windshield, there is a couple of places that looks like could be the culprit.
Is there a problem area that needs to be addressed? I don't want to go guessing and smearing sealer everywhere.
Thanks..Bill
Thanks..Bill
One of many threads on the subject:
https://www.chevyhhr.net/forums/how-tutorial-library-21/fixed-my-water-leak-last-night-14263/
Found it, fixed it, cleaned both surfaces with brake cleaner( after I removed the old adhesive) the cover had sunk in/shrunk a bit so I put an extra dose of sealer/adhesive on it, was not satisfied with the way it looked, did a (McGiver fix) duct tape all around over the adhesive and centered on the edge of the panel. Less than 1 hour. If it does it again, I will put sheet metal in the place of the rubber.There may be a market for such a fix.
Thanks Guys for the help, knowing where you're headed beats guessing...Bill
Thanks..Bill
Thanks..Bill
Brandon (assisting Michelle)
Chevrolet Customer Service
We apologize for the inconvenience. Have you considered trying to find the leak at a dealership? Also, if you would like, I can check your VIN for any applicable warranties, recalls, or programs. Please send me the VIN and mileage to my inbox for info.
pindars
Drivetrain (Excluding Engine)
08-05-2014 06:28 AM
wildman1122
01-28-2010 05:33 AM
