Whacky Gas Gauge
Whacky Gas Gauge
Alright, I can get in my car and be driving around town, with a/c on and my fuel gauge will read 3/4 of a tank. A bit later after running some errands the gauge reads 1/2 full.
Then, I drive a bit further and the gauge will be back up to 3/4 and maybe a little over.
This happens a lot, even without the a/c on. Has anyone else experienced this issue?
I get it when I park on uneven surfaces. Like if I drive to a buddies house it will be on 3/4 then I park in their driveway which is on slope so when I get in it reads 1/2. Then after a little driving and the gas settles it goes back up to 3/4. It seems to take a little while for the gas gauge to catch up.
CH has a point here.
The fuel gauge can be influenced by hills, specifically when driving around town...not at highway speeds. If I remember correctly Sacramento has plenty in some areas. It could be that.
From the manual:
Here are four things that some owners ask about.
None of these show a problem with your fuel gage:
• At the service station, the gas pump shuts off before
the gage reads full.
• It takes a little more or less fuel to fill up than the
gage indicated. For example, the gage may have
indicated the tank was half full, but it actually took a
little more or less than half the tank’s capacity to
fill the tank.
• The gage moves a little when you turn a corner or
speed up.
• The gage doesn’t go back to empty when you turn
off the ignition.
fill the tank.
speed up.
off the ignition.
Take a run up to the Champlain Lookout....definitely not flat getting there
Now will something like that throw off the econ number, or the milage range?
Yves
hah hell one time i almost ran out of gas, car was sputtering cuz this exact thing happened...
it read bout a quarter, rode around doing sme errands, and then it was redline...i was like wtf, so then i made another stop, it went back up about an 1/8...but in actuality it was damn near empty the whole time..luckily i was near a gas station
